Why is SACD not really succeeding?
W
w.e-coyote
Does anybody have insights into why SACD is not really taking off? The price should not be the issue since CD and SACD prices are quite close. In terms of hardware availability there are quite a few players out there that can deal with SACD.
So why are only about a thousand new titles released per year?
dvda-sacd
dvda-sacd
Because the average consumer is not demanding high resolution but MP3, DivX, etc.
Johnd
And the average customer knows little about high res audio, let alone critical listening. They just want to jam w/ their mp3.
Buckeyefan 1
Buckeyefan 1
Probably for the same reason CD sales have slowed since the advent of Napster. People just aren't interested in a library of large round plastic discs. Furthermore, many don't have the equipment to really take advantage of the format.
W
westcott
Another reason is that bass management can be a real pain using analog connections and usually fall short of the capabilities of a decent AV receiver.
If everyone could use a single digitial connection, I am sure that it would be far more widespread. But, as usual, the music industry has cut off their nose to spite their face.
Sleestack
I have one of the few pre/pros that allow bass maanagement of SACDS and DVD-A. Does make a huge difference. Personally, I am very happy with the expanding collection of classical and jazz SACDs.
O
outsider
as so many have said before, the average consumer isn't concerned about quality, they are concerned about convenience.
Personally, I haven't been too impressed with SACD. Sure, it's an improvement over standard CD, but it seems minimal at best.
Plus, I really find multi-channel music annoying once I get past the "wow" factor.
I've actually been considering piecing together a vinyl system.
ironlung
ironlung
Same reason HD video will be just as populuar. The majority don't give a hoot about quality!
shokhead
shokhead
Poor BM in players for sure but sacd and dvd-a isnt for joe blow,its for us as a small section. Also 2 formats and sacd crap selection unless you like classical and jazz. I dont and thats why even though i have a sony,i only have 2 sacd but 10 dvd-a for the dts.
E
ejreiss
Do you think it will be extinct in the near future. I have been putting together a new system and would like to incorporate a sacd player. It would be a shame if it was another laser disc fad.
dvda-sacd
dvda-sacd
No, I don't. :rolleyes:
Since Blu-ray Disc supports 5.1-channel PCM up to 192kHz sampling rate and 24-bit resolution, DVD-Audio is becoming an obsolete format. However, Super Audio CD is a pure audio format and the only one that utilizes Direct Stream Digital.;)
Cheers! :)
FierceTIMbo17
FierceTIMbo17
Very incorrect hd dvd/video is get bigger and bigger by the day, soon it will be huge in not too long a very common thing reason for this anywhere you go nowadays you can somewhat experice hidef tv walmart bestbuy even sams...however there are few places for the average consumer to truly hear the difference sacd makes and most of the places the average consumer will never step foot inside.
WmAx
WmAx
SACD's only compelling feature is the multi-channel ability. In every other way, it is a step back from CD.
1) No feasible way to archive it to a PC for versatile use.
2) No feasible way to rip the digital data and convert to a format for use on portable players.
3) No universal digital output feed to use on your choice of DACs or other digital input selection devices.
4) DSD is not proven to have any real-world advantages over PCM. DSD only entails more expensive and additional purchases for engineers to buy specialized mixing desks. In reality, most convert DSD to PCM and back to DSD after editing, defeating any supposed advantage the DSD was supposed to have in the first place. Quantifiably, DSD has lower resolution than PCM(even less than CDs), once you get into the treble band.
5) SACD and DVD-A do seem to have one advantage that is real besides multi-channel: They are not so often compromised on purpose as CD releases. You can find examples of SACDs and DVD-As that are superior mixes/masters as compared to the CD versions, as the CD versions are almost always mixed to sound the loudest, not to sound the best. Note: the CD layer on a SACD is usually the same master as the regular CD, where as the SACD layer is usually a different mastered version.
-Chris
W
w.e-coyote
Is title (number of ...) availability an issue as well?
dvda-sacd
dvda-sacd
Pyramix converts DSD into 32 bit / 352.8 kHz PCM, what preserves the original quality of 1 bit 2.8MHz DSD signals.
"The damn closest thing to Analog since Digital was invented..."
http://www.merging.com/2002/html/pyradsd.htm
You can see how the Esoteric X-01 gets a DSD noise floor lower than 44.1 kHz PCM, even above 10 kHz frequencies, because of ultrasonic filtering.
http://stereophile.com/thefifthelement/205fifth/index3.html
Besides, I don't agree less noise means higher fidelity.
dvda-sacd
dvda-sacd
DSD versus PCM
Direct Stream Digital (DSD) increases the resolution of music by more closely following the original waveform of the music. If you look at these pictures, you can notice 192 kHz PCM does not approach the analog signal but the 1-bit pulse train of DSD.
Analog 10 kHz square wave -> http://www.smr-home-theatre.org/surround2002/images/show_images/image_051.jpg
10 kHz square wave sampled using DSD -> http://www.smr-home-theatre.org/surround2002/images/show_images/image_055.jpg
10 kHz square wave sampled using 192 kHz PCM -> http://www.smr-home-theatre.org/surround2002/images/show_images/image_054.jpg
10 kHz square wave sampled using 44.1 kHz PCM -> http://www.smr-home-theatre.org/surround2002/images/show_images/image_052.jpg
DSD to 192 kHz PCM comparison -> http://www.smr-home-theatre.org/surround2002/images/show_images/image_056.jpg
ironlung
ironlung
I hope so BUT....There was a day in the not to distant past that the public owned more HDTVs than MP3 players.
Draw your own conclusion. Do people want easy, handy sound and video that's "good enough" or do they study the details in their viewing/listening room?
I am drawing my conclusion from what the average walmart shoppers track record has been so far.
I would love it if I'm wrong.
