mnnc said:
You traded in the Chevette for a Vette! You simply purchased newer, better equipment
That's a matter of opinion! And my opinion is different (as you can tell by my screen name).
You didn't necessarily get BETTER sound, as much as you got DIFFERENT sound. Yamahas tend to have a very bright sound, that JVC does not. I, and a good number of other people, don't care for the bright sound, that some receivers and speakers produce. The brightness fatigues our ears, after listening for awhile. Will give me a headache, if I listen too long.
Some people prefer a bright sound. You must be one of those people.
So, it's really comes down to personal preference. That's why a lot of us will tell people to go listen to different gear, instead of saying that you should buy a particular brand. Most people just suggest you buy the same thing they have, because that's what they have experience with.
When someone wants a brand suggestion, and wants bang for their buck, I suggest JVC. If they have a big budget, and wants a receiver that works well with about any speaker, I suggest Denon. If they say they like the bright sound, I suggest Yamaha receivers, and the small Klipsch speakers. Big Klipsch speakers are a different story.................
Good luck, and enjoy your new receiver.
