All things being equal, I wouldn't buy a receiver over another just because it's slightly more watts per channel unless that watts per channel difference was double. Sony rates their receivers at 6 ohms, so their 100wpc rating is more like 70wpc. If a Denon receiver is rated at 110wpc into 8 ohms, that barely provides a 1.5 dB gain, hardly noticeable. Pick a receiver that has the features you want in the price range you can afford.
A lot of people also seriously overestimate the amount of power they actually need. Playing at reference level, which a majority of us don't do, requires enough headroom to reach 105dB on the speakers end and 115dB on the subs end. Assuming your speakers have a sensitivity of 88dB and you're seated 12 feet away, this can be achieved with a mere 50 watts in a 5.1 system.
I'd be more worried about the sub. Even if it has adequate power it's likely to reach a physical limit trying to get to 115dB and would require multiple subwoofers to make it.
Sent from my SM-G360T1 using Tapatalk
