I recently purchased a new home that is fairly well "wired". I'm interested in installing a "whole house multi-zone audio" system. There is speaker cable wired to each room in two locations and Cat5e cable wired to a wall in each room, I'm assuming for volume controls. All the wiring comes back to a central closet/location and my "main" house computer is directly next to the closet.
I understand the concept of what needs to be done, but could someone point me in the right direction as far as "do-it-yourself" equipment for this type of project?
I've visited websites for products like NuVo and various others, but that seems a bit extreme [high priced] for what I am looking for and their products seem to be limited to dealers.
I'm totally comfortable with speaker installation and any wiring I might need to do, I'm just not quite sure where to start. Additionally, would these types of systems allow me to use my iTunes library as the source for the music?
Thanks for any help.
Robert
Thanks for the quick responses. This definitely gives me a good starting point. The URC products look pretty good.
I'm dealing with 8 zones and I was thinking in the $2,400-$3,000 range excluding speakers.
My goal was audio only available to any zone with perhaps four different sources....but I'm willing to drop it down to two different sources depending on the budget.
From what I've read/heard, I'd like for the controls to be digitally based so I'm assuming this rules out the more "basic" design of a few amps and pot-style volume controls.
I'll do some more reading but thanks again for the responses.
Robert
Does all of your speaker wire come into one central location? It's tough to tell from your post.
Regardless, here's the absolute best, most cost effect way that I can think of to do 8 zones and 2 (or more) sources. Assuming all of the speaker wire is run into one closet.....
1 - Sonos Bundle 250. Cost: $1000 (two sources - one without an amp, which is covered later). This is available through dealers and comes with a fantastic touch screen controller. If you have an iPhone, iTouch, or iPad DO NOT buy the bundle because you can use either of those as touch screen controllers with Sonos for FREE. Buy 1 - ZP120 & 1 - ZP90. Cost: $850. If you want to add more zones/sources to control independantly, great! Just buy more zone players as you want to expand @ $350 (non-amped) - $500 (self amplified) each.
1 - Sonos Zone Bridge $100 (plug into your router)
1 - Onkyo TX8255. Cost: $160ish. Plug ZP90 Zone Player into this receiver/Amp. Will allow for local radio not broadcast over the internet as well as the ability to add other sources.
2 - Dayton Audio TS-4VC 2-Source 4 Room Selector Switch. Cost: $185 each x 2 = $370.
Total Cost (assuming NO iTouch, iPad, iPhone) : Considerably Less than $2000. If you wanted to go to 4 zone players to mix and match sources and control throughout your 8 zones you're still under $3000.
I am assuming that there is NO speaker wire run to where the key pads are? If there IS, than skip the selector switches and purchase impedance matching volume controls at about $20 a room and use those instead. This would be the ideal thing to do if possible. The switches from Dayton audio will require you to go to your equipment rack/closet to turn individual rooms off or on. In practical use, this is not a big concession for most of our clients.
The problem you're going to have is the brain of the person who wired your home. Not that they aren't smart, just that they might have wired your home in such a way that your options are limited &/or expensive. Without question, in the 10 years I’ve been "InTheIndustry" Sonos is the absolute KING of whole house audio at this point compared to anything else ever created for the market. Nothing touches it on any level or any price. To do 8 independent zones with 8 sources on board/16 source capable and full touch screen control (no in wall volume controls or key pads needed) you're looking at around $4000 if you have an itouch, iPad, or iPhone. That's dirt cheap compared to anything out there for that many zones/sources/rooms for a system that nothing else compares to.
Oh, and did I mention...
- It streams Rhapsody, ANY internet radio station broadcast over the internet, Pandora radio, Sirius Satellite Radio, Napster, your own personal music library, and much more right out of the box?
- There is literally under 10 mins of programming. Easiest thing in the world for an end user to set up.
- Yes, it will allow you to mess with your iTunes. I doubt you'd want to after using Rhapsody, but you can.
Lastly, and I don’t want to sound snarky, but whole house audio is a luxury item. As are most things in the consumer electronic industry. Meaning: You gotta’ pay to play. Think of it like this…. A manufacturer assumes that someone with 8 zones of audio in their home has a larger home. Larger home = Larger income. Larger income should = Larger disposable income for luxury goods. Bigger is more expensive and it should be because… it’s bigger, costs more to engineer & manufacture, etc. Go down to a 4 zone system with keypads and you can get away with something entry level, plug n play from Nuvo for $1000. Sonos is still much much better and less expensive because it includes sources that the Nuvo systems couldn’t begin to touch . I know because I’m still an authorized dealer of Nuvo even though I haven’t bought a Nuvo or any other keypad based product since I discovered Sonos 3 years ago. There’s no sense in it.
www.Sonos.com Hope this helps!
