Which of these 2 receivers for my setup?
tdamocles
Joban said:
I don't think that you could go wrong with any of those choices.
I just picked up an H/K 135 which is rated at 40x6 (or 50x2). My room is about 12 x 16 feet and I only have 4 speakers going (none of which are particularly sensitive) and do just fine. I usually listen at -20 dbl and it is loud enough for me. Unless you have a massive room or really inefficient speakers I think that you would be fine with 55x7.
I don't find that H/K difficult to set up either. With onscreen menus it is straight forward.
In short, the H/K is a contender but that's not to say that the other 2 receivers aren't great choices either.
Cheers,
What are the sensitivities of these speakers? Have you tried listening in stereo at -20 dbl? I've had the opportunity to listen to the avr230(in stereo) with 96 db sensitivity speakers and at -30 to -35 dbl it was all but ear bleeding?.?.?.? Are my ears that sensitive to sound?
Joban
The fronts are JBL HLS 610 rated at 88 dbl sensitivity. I'm sitting about 10 feet from them. The rears I have are even less sensitive.
Last night the neighbour underneath my flat was out so I tried 0 dbl on the AVR 135. Really loud obviously but not that distorted ugly loud. Really impressive actually.
All this will change when my Axiom M60's arrive - rated in room at something like 93 dbl.
The AVR 240 has an extra 10 watts per channel but it is also rated at +-35 amps rather than the AVR's +-25. Not sure if that makes a big difference or not.
I was actually hoping to get the AVR 240 but up in Canada H/K costs a fortune. I have no complaints with the 135.
Cheers,
Jordan
