1)You took both home?
Yes I took both home.
2)Listened in 2-channel or 5.1?
5.1
3)What was the source?
pvr, cd, dtv reciever
4)If not at home, where?
at home, same speakers, same room, same components; the Yamaha is a complex animal to set up. The HK out of the box, sounded great,
5)How did you have the HK set-up?
Large main, small rears, small center, 5 ch stereo, the HK had a lot of juice, the yamaha just doesn't have the quality or the quantity.
6)If you listened in 5.1, did you have the speakers set to small?
see above
7)What was the crossover set at?
40hz;; the f2 bottom out at 35, and the b2's bottom out at 50 hz
8)Was there dead silence when you ran YPAO?
