Which is better? 1 sub or 2 subs?
kirbyevie
kirbyevie
gene said:
2 subs are ALWAYS better than one sub, especially in small rooms. It's not about the added SPL as much as it is about superior modal control to achieve smoother bass response in a wider listening area. If budget is a concern go with the lower model and get 2 instead of one higher model unit.
Check out our Setup Tips section for articles on this topic.
Thanks gene,.. I might take the last 2 units on their stock. I want to look for other brands and manufacturers of sub but the market here in dubai is limited.
Anyway, thanks for the suggestion... GOD Bless
mulester7
mulester7
kirbyevie said:
Hi Billnchristy, well Dubai is growing so fast now. there are a lot of construction going on,.. I mean, massive construction. Still, Dubai is a very busy city and a lot of places for hang out. It's been a long time since you're here, try to spend your vacation here in Dubai.. DSF (Dubai shopping festival) will start early this year. GOD bless
.....real nice.....
gene
gene
Audioholics Master Chief
Administrator
Well, JBL Harman research, very extensive, would show this to be true and actually would dictate 4 as best. But, not sure 'Always' means 100%. May need to re-read their research. Perhaps there may be an exception someplace?
4 subs is best in rectangular shaped rooms. 2 works almost as good, especially if you EQ them properly.
majorloser
majorloser
Moderator
4 subs :rolleyes:
Now that will take some serious help getting by loserwife.
His room is 26ft x 33 ft. I think that is somewhat rectangular. :D
majorloser said:
4 subs :rolleyes:
Tell her it is just decoration:D Put some statues on it or trinkets:D
kirbyevie
kirbyevie
4 subs?! I told my wife about this,.. she theatened me to take all my credit cards and put 100 DHS (27 USD) every 2 days on my wallet! :eek: :eek:
she agreed for 2 subs! :) thanks guys, GOD Bless you all.
bcpar01
"always" is a strong word
Always is way too strong of word in a complex situation such as this. Without going into unnecessary detail, take a look at the graphs of the data obtained in your link to harman.com that show their experimental data of subwoofer configurations ranging from 1 sub to 18. "Always better" is not just too strong, but incorrect in this situation because of problems with wave interactions. True multiple subs are usually better in a situation with seating in different areas of the room, but this is not this case with everyone's HT room.
