I recently purchased a Toshiba 46" DLP television and a Toshiba S97 DVD player, both of which are on their way here. The next purchase is the HDMI cables to connect the two and I actually just made that purchase online a few minutes ago, but now I am having doubts.
I figured I would come here for some advice on which cables to purchase and I cam across a couple of sponsors here on this website. I figured that if they are sponsored here then they must be recomemded.
The companies I had to choose from were Impact Acoustics and Ram Electronics. I was looking for a short (1m) HDMI cable and I decided to make my selection based on price. However after actaully reading about the Impact Acoustics cable it just sounded so much better, especially for it being only $10 more. You can compare the two here:
http://www.impactacoustics.com/product.asp?cat_id=2605&sku=40278
http://www.ramelectronics.net/html/DVI-hdmi_cables.html "RAM's new Rev2 "High End" HDMI Cables"
Impact Acoustics summary of their product is just so much more comprehensive that it makes me think that the Ram Electronics doesn't have nearly the amount of features that would allow it be capable of providing as good of a picture.
Did I make a mistake with my purchase? Should I cancel my order and get the Impact Acoustics? Is there really going to be a difference? Any advice would be appreciated. Thank you.
