what's the point in 6.1, 7.1, 9.1 surround sound?
Mr.BBQ
Mr.BBQ
I'd say stick with two surrounds, it's all you really need at this point in this time. I'd invest my money in bigger, badder fronts :D
bryantm3 said:
that's about what i thought. i'll be fine with 4.1 or 5.1.
No, don't count on 4.1 as being fine. You need a center speaker, that makes it 5.
dougpy
But is it possible to just have one rear chanel with a 7.1 reciever? I have two rear speaker outputs...
I really don't want to buy two speakers, since I'm not even sure I care about the rears.
tomd51
tomd51
Hi dougpy, welcome to Audioholics! ;)
You can certainly run just one rear surround w/a 7.1 receiver, one of the two surrounds will be designated (typically the left rear surround) for the '6' in the '6.1' configuration.
I'd suggest looking at the back of your receiver or the user manual to determine for sure which speaker terminal to hook up to, then make sure you change your receiver settings to accommodate for the additional speaker... -TD
dougpy
6.1 indeed
Thanks, according to the manual of my Onkyo TX-SR804 (which I love) 6.1 wants the back speaker to plug into the left back output.
Joe Schmoe
This thread got me thinking about something: A center channel anchors the dialog for an off-axis listener, but what about everything else? The mains and surrounds essentialy act as two (or more) stereo pairs, and stereo imaging is generally not good when seated off-axis. Is this really an issue? Does using more channels help if so?:confused:
Warpdrv
Warpdrv
I battled the thought of adding a rear to my 5.2 setup... because I have my system laid out in the corner, with my Plasma in the corner, then my rear would go in a corner as well. I honestly thought it wouldn't make a big difference. I bought a single Di-Pole for that rear corner. I thought my system sounded amazing with my 5.2 setup, but adding that rear made movie watching a completely immersive experience setting with the right movies. It sounded amazing, and I wouldn't go back to 5.2.
The choice of rear speakers (Direct or Di-Pole) IMO depends on how large a room you have, and how far back from behind the listening position you can get. And your intentions of use, Movies/Games/Music.
Also keep in mind, if you do alot of gaming, the 7.1 soundfield is quite accurate. Things coming up from behind should be localizable and are best reproduced with direct radiating speakers, Di-Poles don't reproduce this very well at all. I have found they tend to just smear those sounds out behind you... I don't do any gaming, but I have had some experience with it on my setup for a short time.
For movies I found the rear Di-Pole works in my environment just fine, and movies are a completely different, 100% better. Many fanatics will argue about what speakers should be placed as side surrounds and rear surrounds.
To me it really comes down to your room layout, and choices of material.
Music will not sound right coming out of a Di-Pole speaker, it can be done, but with poor results. Some rear speakers are switchable from Di-Pole to Bi-Pole.
Obviously results will very, as well as opinions...
Warp
