Whats next for my "FRANKENSTEIN" sound system in my man cave/garage!
AUDIOisLIFE
As for crazy too loud cant sit in car loud!!!! Craig Butler hit 182db but you cant sit in there. It will not make you loose hearing it could possibly kill you. He has to bolt his doors shut!!! As of now no one has died from sound but some scientist say that db this high MAY cause hart failure dew to the pressure etc. causing irregular hart beat or heart attack.Some even say it could cause your lungs to collapse. Military and riot police use sound a lot for crowd control, with a large single speaker "LRAD" long range acoustic device. Now that's painful sound!! There is a difference in between a concert with loud vocals/lyrics VS low tuned subwoofers, 30hz and below. More pain with loud vocals screaming in your ear then a low frequency bass. I challenge you to find something to change my opinion on car stereos! CALL THE MYTHBUSTERS
Back to origin of topic! I want to improve! As I said before my car had very large woofers that I hooked up in the garage but the bass was over powering. Now I could stand the bass if I was able to get the other sounds to reach the same level or louder!! But that was with car audio RIGGED up with my own scary power conversion. I don't know much about home audio, but $500 for this Klipsch? I could have gotten 2. 2000 watt amps "car audio" or close to 3 15" DVC subs. That is way better than the price for SVS PB-4000! With that being said its almost as though I could build a custom sound system myself, as long as I fallow air and power spec. That would possibly be louder and cheaper. Or buy home audio speakers, Dayton audio being one I've looked at. And building and make my own. Again I'm not understanding power ratings on home audio in comparison to car audio, aside from volts VS watts.
AUDIOisLIFE
So far I have …
$360 DriveRack PA 2 Management Processor dbx2 OR
$150 BEHRINGER SUPER-X PRO CX3400
$120 BEHRINGER ULTRA-DI PRO DI800
$600 Denon AVRX3400H OR AVRX2400H $100 less
1.x $350+Crown XTI 1000 ,if I can find them!! OR $500 for 1002's for mids/highs
2.x $999 Crown XTI 4002 for bass
$TBD...Furman Power Conditioner
And is the setup I had in thought for car audio Subs, mids, and highs. Don't know any home audio speakers this loud for price.
Could use a lot of this for home audio but from what I understand from earlier post is the power rating on home audio was something like heat rating? So they would not hold with this power.
The bass power could be changed also, made this list with (2) $550 Team FI - BTL Series – BTL-NEO12's in mind. But that's my all out. Could go way cheaper, (2-4) $200 American Bass XFL1522 15's
Mids would be (4-8) $150 Team FI - N.7 Midrange's
Highs (4-8) $70 Morel CAT 378 1-1/8" Tweeters
And make costume enclosures for each range "mids/highs" and woofer separate, or make two towers speakers. Aprox PRICE 5,600 cheaper subs, 300 or more for. More expensive.
