mtrycrafts said:
OK, when are you doing the experiment??? Or just guessing on the answer?
Also, what will it tell you if one runs 3 hrs and the other 4 hrs? Will that tell you which sound different? Which will play music or a movie better?
Or, are you looking for an amp to use in a club to run all night at 120 watts or whatever their full power is, continuous? I am outa that club in a flash.
It's almost like asking which car will run at red line for the longest?
It's an educated guess based on the weight of the units/size of the heat sinks. I would think running the Yamaha at full bore would trip the protection circuit after a few songs, not hours at levels just below clipping.
Try running each amp to some 4 ohm, 85dB towers, and time would most likely be of concern comparing the Yamaha and McIntosh.
I was simply providing an example why one amp would differ from another with the same wattage rating. I can't speculate how large people's listening rooms are, nor their listening tastes. I listen to my system quite loud - not rock concert levels, but do enjoy the slam of a good bass drum, something very hard to obtain with my 3805 and RTi10's compared to my audio system in my truck (even with a 12" HT sub). *A lot of that has to do with the spl/Hz rating of the speakers, as does the size of the listening environment*
A guy over at the AVS forum asked if a mid level receiver would power his Polk CSi5, RTi12's (front), and RTi10's (rear) in a very large room. I would be much more comfortable recommending he obtain either a flagship unit, or a Yamaha 2500 with at least a two channel amp (like the McIntosh) to take the load off his receiver.
