Hey all,
Before anything else i want to thank you for taking your time in reading this and for any help your willing to give
So here goes, I'm currently looking to get a new 5.1 system for my home, now I know the room is a bit weird but it's what I got for now.
I'm looking for 3 different possibilitys:
1st - would be a system without thinking of the future and to be used forever in this layout;
2nd - second a system with the idea of upgrading in the future to a bigger and better room
3rd - lastly and the one that interest me most a combination of both the possibilitys above but a set up that will not be all bought at the same time (for example buying all the speakers first and getting the sub a couple of months later, or using satellite speakers for front and after changing room getting new tower speakers for front and then going 7.1, for example)
So if you don't have time for all 3 possibilitys just please give me the first or third
Again thanks.
Now for what you need to know:
It's going to be working with a 42'' LED Full HD, an XBOX360 (HDMI) and a computer (RGB + optical) and the occasional laptop (HDMI). Blue ray reader is not needed
Budget : 1000€ to 1500€ (in US dollar its 1280$ to 2000$) initial with the possibility of an extra 500€ to 750€ (640$ to 960$ US dollar) a couple months later
About me: I'm in Portugal so getting gear available in my country is a plus or from Europe, preferably UK. A quick way to find out if something is available is using this website (in portuguese)
kuantokusta all you gotta do is put the item your looking for in it and if it shows up then it's available in my country, if this is too much hassle don't bother and I'll find a way to get it
Also, I'm a fan of mourdaunt short despite them not being available in Portugal but they are in the UK so I can find a way to get them, and I really like hearing those low frequency so I'd value a good sub even though I did suggest getting one at a later stage
I'm looking for any suggestion, even a home cinema kit or a full custom build.
I'm going to try to add a picture with the layout of the room, please bare in mind that's it's not exact it's a merely a sketch and the red spots are where I currently have a really crappy 5.1 system.
Once again THANK YOU for putting up with me!
