2 things.
First, the subwoofer should be a good one.
Second, it should be in good working condition.
If it does not work properly, do not buy it. Do not buy it if it is a bad model.
So, make sure you listen to it before you buy it, and make sure that it is a model that is worth owning before you bother with going to listen to it.
