8118 said:
what do u mean by "put the two rear surrounds in front (don't know why you would)". I got a 10" sub and pair of old front speaker, the front is still doing good, but just thinking to have another pair of speaker since my denon support it. workable? worth to spend?
There is no need for 4 front mains. Juts because your speaker can support it, does not mean it's the best way.
Some people run two sets of mains with one set being geared toward 2 channel and the other for HT. These people use the different pairs at different times.
Like others and myself have mentioned, adding two additional speakers is not the way to improve sound. It tends to muddle it up. The way to improve sound is the upgrade your two mains.
If you are wanting HT, I would try and get two mains and a center. For under $1k, you might start by auditioning speakers by,
PSB
Athena (awesome deal on the AS-F2 right now if you can find them $400/pr)
Infinity
Polk
Boston Acoustics
MB Quart (for you Zumbo
Klipsch
Mirage
Paradigm
Definitve Technology
Phase Tech
Energy
to name a few. All these companies make good sub $1k speakers. You just need to get out and listen to some. Listen to other people's advise (like mine) to get idea what's out there. Don't and I repeat Don't let anyone tell you one speaker sounds better than another. It's up to your ears.
Shinerman
