Many, if not most "remastered" recordings are shells of the recordings they once were. More often than not, it makes me question the age of those who do the remastering, relative to the age of the album.
Speakers are B&W DM-310s...
I have a sub on order, but wonder if a center speaker wouldn't have been a higher priority.
ssn vet
I'm going to go with MrBoat's first thought here and recommend a purchasing time out while you evaluate your real need. I can vouch for the vast differences in source material. Even with the same band, like Chicago, there will be large audible differences between CD titles. I would recommend a sit down listening session (free) with a range of titles and see if you hear a problem you can identify, or, are we chasing windmills here.
Secondarily, and probably just as important, is the variability within our own musical experience. There are days and times when our best sounding stuff sounds "off". That's not the hardware doing that, often times its our own internal soundsystem : brain + 2 ears. This variability can't be overstated. I know when I sit down and stuff just sounds off, the problem isn't my hardware. Its me. It happens and the only fix is either another frosty cold beverage, or, shut it off and try again later when the mood is better.
The good news is that you are running hardware (the B&W 310s and a 70watt avr) that's not terribly expensive but pretty good. If you like the way it sounds, great. Keep it up. If you come in to the idea you'd like to upgrade, you are in a spot in the spectrum of speakers and AVR's where you can get a great upgrade without breaking the bank. In other words, from where you are, an upgrade should be pretty easy when you have the coin assembled.
I am a huge proponent of saving enough money to KNOW you are buying an upgrade instead of trying to spend as little as possible and HOPING you are getting an upgrade. Saving takes time, but it pays off because it gives you time to audition, research and get your hopes up.
Anyway, that's my 2 cents.
