Thanks for reply KEW. I forgot to mention that i am also planing to upgrade my speakers to 4435, but they are very rare, especially in my country. I'm from Serbia by the way. I also forgot to mention that i have Also have a Pioneer S-W1EX Subwoofer from their high end Excellence series. Sub is very well built, it has a separate amp from the sub box and a passive radiator. The sub gives a very tight bass and also goes very low. It fills that gap that L90 have in lower end. Also when i moved to a bigger room, the lower end became more noticeable because of the wave length of lower frequencies. Yes i am a passionate audiophile striving for the best sound possible without spending 20k. As i mentioned, i plan to upgrade, but the speakers are very rare, and to ship from Europe is almost impossible. So i have to wait. On the other hand, there are plenty of amps here on the ads + diy building is utilized very much here. L90 with modified crossovers sound very good, so it will have to do the job with the sub until the speakers appear in the adds, usually once, twice a year. I would like to upgrade the amp until then. Someone suggested me a First Watt F7, but its also Nelson Pass work so i think it will sound similar, also only 25w, that will definitely not be enough to drive 4435 when i get them. My room is acoustically treated by plush curtains for better sound, i plan to put Skyline Diffusers soon. Here is a video of a setup in a previous room, back then i used a modified Marantz CD40 player, also played a flac burned file. The sound is bad because i recorded it with Samsung S3, so there is no bass in the video, but it gives decent vocals. The sub is not turned on because i dint use it for drum and bass, the sound is not linear, L90 can give plenty of bass for dnb bass lines. Even if it is declared to go 70hz on axis, it actually goes down to 35hz +- 5dB, i dint listen that loud so it fills the room with li near bass. About the stores here, there are baerly any, and they usualy sell only new speakers, and not that high end amps. I would like some amp that is diy buildable, because almost all of my system is diy built. Yes Pass labs isa very capable amplifier. But i got used to the sound and would like to change a little, and also upgrade, I'm sure there are amps that can sound a little better, and definitely different. Even though i like neutral sound, maybe some amp that has a little coloration. Thought about tube amps, but they are low on power. A class is not absolutely needed, but would be good. mtrycrafts i cant see the pictures but i will look into the thread, thanks both for reply! Here is the video. Cheers
