What kind of mount for these speakers?
tonbo
They're no-names--JWin--and I can't figure out what kind of mounts to use for them (as opposed to shelves.)
The only mounting thingy I can see is a 1.25" hole on the back--not a screw hole, keyhole or anything else. Just this big hole.
Any ideas on what kind of mounting device to use?
ParadigmDawg
ParadigmDawg
That big hole in the back is the port which means you shouldnt mount these on the wall. You will need to use speaker stands and place them 12" from the wall.
agarwalro
agarwalro
Greg's right. You need to keep at least 10" - 12" space between the speakers back and the wall for the port to work properly.
