What is the most Popular back-wall paint color?
jostenmeat
I wouldn't worry about it in that room. I assume this is for video improvement, and well, I would honestly just go with what looks best, because video improvement, if any, will be pretty marginal I am led to believe.
If you ever DO need a black paint recommendation, here is one:
The blackest, most flat paint. Period.
Y
Yamaheart
Well, Thanks jostenmeat. It is not about improvement, I just got bored with the look. I might re-arrange something and go with my instinct for a new color. Thanks.
jostenmeat
Ah. I would start looking for interior design forums, or something. Lemme try looking. After all, you're asking someone who just built an unfinished 23 cu ft subwoofer. Maybe I'm not the right guy to ask. :p
http://www.gardenstew.com/forum-14.html
http://www.topix.com/forum/arts/interior-design
Ah, this looks to be the same software that AH uses, so it should be easy enough there, for you:
http://www.city-data.com/forum/home-interior-design-decorating/
Ok, lemme try interior decoration:
http://forums.about.com/n/pfx/forum.aspx?webtag=ab-interiordec
Someone recommended this site to help yourself figure it out:
http://www.armstrong.com/flooring/design-tools.html
http://forum.doityourself.com/decorating-design-30/
Well, I guess that's a lot. I hope you find something worthwhile . . .
just-some-guy
just-some-guy
nice room. if it were me. i would be looking for a color to paint the ceiling. perhaps something to compliment the floor. that white just isn't going it for me.
as always = ymmv.
Y
Yamaheart
What do u need to build a sub? What component do you need? That interest me a lot. Can you guide me thru it? Thanks man.
jostenmeat
Mine was much much much easier because it was a pre CNC'd kit. Pre cut, pre drilled, etc. There is no way I would even attempt a tapped horn otherwise. Call me a wuss, I don't care.
Anyways, I am soooo not the guy to ask. There are already designs that people have shared with each other, and that's what I would do (because they already figured out the math for you, with specific driver parameters in mind).
If you needed a special one of a kind build to certain specs, then a lot more work, or a lot more help would be needed. Go hang out in the DIY forum here. Check out the stickies too. There are a number of people who will help you. Probably not me though, sorry! :eek:
Y
Yamaheart
Thanks man, Ill probably do 1 in the future and named it Yamaha. Hahaha..
E
ericeroi
I like the two colour effect to make room interesting. I have green leather sofas and brown and black furniture so painted the room to match. Even made some panels to match the colours also. I had to work around the constraints my wife gave me but I'm pretty happy with the results. I reckon a nice brown on the back wall would go well in that room and fit in well with the equipment.
Since this is my first post, I've just found out I can't post the pictures I've taken:(
E
ericeroi
Thanks for that! Here's the pics (rubbish camera which doesn't bring the colours out too well):
