keep in mind your receiver will end up converting everything to PCM if you did use bitstream, PCM is raw digital audio data, the stuff that ends up going to the DAC. as long as you are getting the proper amount of channels (5.1/6.1/7.1 etc) it is no different. also you should be able to get DD on a ps3, mine outputs DD on all DD games. its not a slim.
