Lordoftherings
Lordoftherings
A Pre/Pro is a Receiver without the Amp section.
* Also, it sometimes includes the Tuner section, and sometimes does not.
New to this. Thanks in advance for answering.
In the old days or analog it would be called a preamp.
Today, it has all sorts of sound processors associated within so the name.
Lordoftherings
Lordoftherings
^ Thanks for the distinction.
* My guess was that the OP was asking in reference to a modern A/V Surround Receiver.
Then, in that case, a Pre/Pro is as I mentioned before.
So, a preamp more precisely, with processing for Surround sound and of course, Video Processing. Only the multichannel power amp section is missing.
And like I already said, the Tuner section nowadays is also included, so is all type of digital tuners accessibility, plus Ethernet and Internet as well, Ouf!
That is a lot of Processing power indeed.
** It's true that in the past, in the world of Stereo, a preamp did not have a
Multichannel Surround Processor, only Stereo, and still not even (in the old days).
Also, the Tuner section was missing (that was the norm, more than the exception).
agarwalro
agarwalro
Pre = Pre-amp, Pro = Processor.
The pre-pro serves the following functions:
1) Pre: Act as switch connecting all inputs to output (audio or video)
2) Pre: Bring analog signal to line level for amp input
3) Pro: Perform Digital to Analog audio conversion
4) Pro: Apply any changes to sound or video when compared to source. Eg. equalization or bass management, video noize reduction.
So you can have Audio only pre-pro (sometime called simply pre-amp) used with a power amp, Video only pre-pro, a pre-pro that does audio and video and finally the Audio Video Receiver (AVR) is a single chassis containing all the audio and video pre-pro and the power amplifier.
CraigV
CraigV
The “pro” part will also decode surround sound material. Depending on the age and cost, this can include all the latest codecs, like Dolby TrueHD & DTS Master. It then steers the sound to the appropriate amplifier channel to be amplified. Some people will contend that this is the means to get the best sound from a system, but using a receiver that has pre-am outputs and a good external amp (like an Emotiva) will afford the listener more head room, and an overall boost in sound quality.
