What Did I Build This For?
I am now pretty sure that the panels will be on the roof and what you see is for some equipment related to the system. Perhaps and inverter or two.
With that fixed brace in the back and the solid 4x4, distance to wall is limited.
You are correct. It is solid and I designed it. I built it last Saturday with my son in law. It was a two man job. It is extremely rigid and is a tensegrity structure after the late Buckminster Fuller (Bucky).
The concrete was poured six days prior. I built the rear beam prior, with L-anchors and nylon washers so the beam does not touch the concrete, which would be a code violation.
This was placed when the concrete had cured the requisite amount, plus the bases for the cedar 4 X 4s, they have anchors and keep the posts above the concrete.
To-morrow will be final construction day hopefully, and more details after that. I will be working with the crew to get things absolutely correct and make sure there are no code violations. I had the inspector around prior and he said he usually fails these projects at least twice. I am going to make sure we get a first time pass.
There is a generator as you can see in the above pictures and I post again below. It is a 20 KVA Cummins auto start with an automatic transfer switch in the utility room.
Batteries are no longer recommended as they don't last long enough and the cost of of the initial install and replacement are too high. So two way metering is used. So a lot of the time I will be supplying neighbors. The estimate is that it should provide 75% of my electricity usage, and therefore I will have two electricity bills per year instead of 12. The way the utility works this, is that there is one make up bill a year. If you should happen to produce more then you use, they send you a check.
On site is the best place for solar, as the DC/AC conversion loses 25 to 30% and you lose another 30% in line loses from the solar farm. So generating at home is much more efficient.
It is now snowing hard. We had a heavy cold rain all night and now it is snowing heavily. The ground is still warm as it was 80 degrees two days ago, so I don't think it will settle much.
Tomorrow is supposed to be sunny but only 47 degrees, so I will have to put a warm sweater under my overalls. I expect to be out doing this all day, so don't expect any more updates until Saturday.
I am hunkered down and baking bread today. I have baked all my own bread for 8 years or so now. It is seems really romantic to be baking bread when there are huge snowflakes falling fast outside.
I will post the picture that shows the generator outside once more. The fixation is totally "Caterized" and will not go anywhere. I fabricated the fixation device myself, and it is "right by design."
someplace to hang your Trump sign ? ;)
I am not a garbage Trump supporter, but the Harris signs are covered in snow today. Nature played a Halloween trick round here.
They have lowered the high temp forecast for tomorrow for 46F
ryanosaur
ryanosaur
@William Lemmerhirt , I hope you are already running the snow blower, otherwise you won't make it to the grocery store before you have to eat one of the kids! :eek:
:p
William Lemmerhirt
William Lemmerhirt
:p
Haha! That’s just mean to say that.
I mean eating children to survive? That’s fine, but the snowblower? Sheesh…lol
I am a couple hours north of TLS guy but we fortunately haven’t seen any snow yet. However…it is currently only 40°. Gross.
Btw happy Halloween!
ryanosaur
ryanosaur
Wow...
That means you've at least considered it... once or twice.
:eek:
Obviously you haven't carried through on it, which is good. I don't condone eating children. Just Foie Gras and Veal.
:D
William Lemmerhirt
William Lemmerhirt
Wow...
:eek:
:D
While I certainly wouldn’t do it, having two 17yo at home at the same will make people consider things lol. All kidding aside, they’re great kids. Big brother was home this weekend. Really nice time.
Now about this veal. I’d like to try your handiwork some day.
Does the generator run on natural gas?
Very nice pictures.
Not a good day for solar if you'd have it now. :D
Wow...
:eek:
:D
There is always the "dogs, cats and the geese!" Lots of geese in Minnesota.
GO-NAD!
GO-NAD!
I live around the same latitude as Minneapolis, but we had record high temperatures yesterday.
We have wired Ethernet all over the house. Only mobile items use Wi-Fi. The Internet comes into the house next to the panel and goes to the modem and router, and then to a 19" patch bay, there are two 19" rack mounted hubs in the studio chase. There are patchbays for the security system, one each in the family room, great room and office.
Are you using monocrystalline panels?
