what are you drinking right now ?
G
Grador
Some Ozeki Taruzake, ceremony sake. This proclaims to have "hint's of ceder and woodsy aroma." This is in fact a lie, it is very cedery and also quite good.
macddmac
macddmac
IPA on nitro at elk mountain brewing.
Gotta get me a nitro setup for the kegerator !
tomagardner
Mmm, have't been to Elk Mountain yet.
Sipping on a Breckenridge Regal Pilsner. Happy Halloween!
STRONGBADF1
STRONGBADF1
I picked some of that up on the way home tonight. I got a "Best of Belgium" 12-pack with three of those in there. I'm drinking a Stella Artois right now...it's okay.
I bought the case. 12 Stella's, 6 Hogaarden's, and 6 Leffe's.
First Leffe I've had... Different, I'm not sure about that one. Hoegaarden is good summerish beer and Stella's are a nice all around "yellow beer" as my sister calls them.
On a side note. Beer prices have gone up again and the micro-brewery's are getting out of there minds. $40-$45 cases of beer that aren't rare or special. The best of Belgium case was $30 and I wanted to try the Leffe so I picked it up. Honestly I don't know if I think this case is worth $30...Maybe it's the Pennsylvania Dutch kicking in.
Adam
Adam
I got the 12-pack for $13 (on sale), which is why I decided to buy it. Leffe (which is one of my favorites) sells for $9/6-pack at my nearby grocery store. They're normally pricey, though...but convenient. I stopped drinking it after I saw it was 200 calories a bottle because I didn't like the belly that I was starting to get. I got some to treat myself, but I've started down the path of light beer until I get myself exercising more again.
BoredSysAdmin
BoredSysAdmin
Enjoying amazing weather down in St John and drinking BBC
banana, Baileys and coconut
jostenmeat
Adam, there is more than one way to skin a cat. The biggest reason why the Leffe has more calories is because it has more alcohol in it. So if you drink the same number of bottles any given night, yes you'll imbibe more calories. If however you drink based on alcohol consumption, there may be a much smaller difference than you think. I haven't calculated abv/calories for you, but that's easy enough to find.
So if you are the type that drinks the "same amount of beers", I will say that while Amstel Light isn't particularly delicious, it's not bad when you consider it has only 99 calories. How did they get away with that? A very low 3.5% abv. I just saw that while looking up something else.
When I bring some beers when visiting someone (and I'm the driver), I tend towards the lowest abv beers I have in stock, and that is usually Anchor Steam (there is a place near me where I get it at $6-7, but unfortunately it's usually considerably more for many others); 153 calories, 4.9%.
If you like Asahi, the best Japanese beer I ever drank was their Asahi Select. I've tasted it side by side with some Liberty Ale, and I no longer buy the latter after that experience, so I think that might say something. Er, well maybe not, I'm really not a connoisseur. In any case, I haven't had either in a while.
OTOH, if you're the type that drinks the "same amount of booze", you might look into trying out a few cocktails. You will need a Boston shaker (do not, I repeat do not buy a cobbler, but if you already have it, then fine), and strainer (the Oxo one is good, but really they all work fine).
Try this one, a Sidecar. Find a good cognac (I found some extremely smooth XO for $35, but someone told me there is some $20 XO to be had on sale, haven't checked it out). It doesn't have to be top shelf or XO, but quality does make a difference, and anyway, whatever you're comfortable with. Then a bottle of Cointreau (don't buy any other triple sec imitation, stick with the OG, don't go brandy based either like Marnier). So 2:1 cognac:cointreau, say 1.5oz/.75oz. Half a lemon's worth of juice. A small touch of sugar (people use simple syrup, but I find it a pain; confectioner's sugar is easiest as it dissolves immediately, and I have some in a small spice jar for easiest use). By small, I mean tiny, but really just do it to personal taste. Using the highest* figures I found on the net, but not including the sugar, this is 182 calories. (edit: the amount of ice and shaking will come with experience; the dilution is key btw, not just the cooling; "standard" is glass full of ice, aiming for quarter melt, but I hate throwing away all that ice, so use like quarter glass, near complete melt.)
It is a refreshing drink, an old American classic, New Orleans sour to be specific, and is the granddaddy to a number of drinks, including the ubiquitous Margarita.
So speaking of, to make the above a Margarita instead, use same proportions, use a clear plata 100% agave tequila, again only Cointreau (imo), and def not brandy based like the "Cadillac", and with that half lemon, add half a lime too. Or a whole lime, it depends on taste, and the particular fruit (freshness/type gives highly varying amounts of juice). Instead of sugar, you can replace with a touch of clear agave nectar (dark nectar settles and ruins the look). The drink will come out like a semi cloudy white. The way it should be, IMO. A side note, while there are a few that are alright, best to stay away from "mixto" tequilas; I believe those only require 51% agave, the rest of the 49% can be any mystery hangover hell type of booze. I got some Regional brand plata, 100% for only about $13-14 after some coupons I found. Ain't the very best in the world, but it's still better than almost any Margarita that I can find in most any restaurant. Calories are almost identical, add say 5(?) calories more for the half lime.
Cheers.
p.s. oh an easy garnish if you wanted one is to use a vegetable peeler and slice off a nice side of lime or lemon peel. You can also take this peel, and right above the glass, squeeze/shoot the skin's oils right through a flame directly into the drink, using match or lighter, and it will give you a nice subtle sumthin sumthin, as well as changing the bouquet. Also makes for a nice lil show if you're entertaining. Throw in the peel. The more a fruit has been handled, the less oils it probably will have remaining, btw. Oh yes, also, before squeezing the juice from the citrus, rub the fruit around the circumference of the rim, it will provide a nice citrus element, this will be less subtle. Forget salt, I don't understand what is up with that. Then again, I don't understand a lot of margaritas. If both the sidecar and margarita above somehow turn out to be the greatest things you've ever tasted in your life, you can graduate on to the Corpse Reviver family, I think #2 is the bomb, but the products start multiplying.
macddmac
macddmac
Cheers.
Or.. You can fill a glass with ice, pour in 2 ounces of Jack Daniels, and a heavy splash of coke and call it good:D
Cheers, Mac
jostenmeat
Cheers, Mac
macddmac:
I typed out a lot, because I know there can be a lot of uncertainties with certain products and techniques. However, don't let my long post confuse you with a great amount work. I can make a sidecar in a minute flat. Now if you're implying 1 minute's worth of work is not worth it, that is another matter. You know, a porterhouse steak with salt and pepper takes me twice as long to make than a hot dog with ketchup and mustard, but I'll still take the former, even if the latter is "good". The crazy part? Imagine if that porterhouse and hot dog cost the same price.
I never drink coke, regardless, that hardly is a candidate for low calories. Unless you think diet coke tastes as good, I wouldn't know with JD.
Another issue with cost/waste with using coke is that once the can/bottle is open, you gotta use the rest that evening, unless you like flat soda.
Also, I personally find it easily worth spending a few more dollars for a good bourbon over JD.
I do find that muddling is more work than shake/strain, but I thought about it because the most common whisky drink I make is an old fashioned. I muddle an orange slice, Luxardo or brandied cherry, dashes of whatever bitters I feel like, whisky over rocks, stir. I just made one right now, curious how long it would take me.
With whisky still in cupboard, orange slice wrapped in plastic in plastic bag in fridge, cherry jar in fridge, ice still in tray in freezer, bitters still in cupboard, I timed it:
1:14 drink is composed, 1:30 thoroughly stirred, 1:56 orange peel is in trash (I could've left it in drink, btw), measuring glass/barspoon/muddler are all rinsed (but not washed with soap), plastic bag is in recycling bin.
My command of the English language is not great enough to competently describe how much better of a cocktail this is over a JD and coke. Seriously, under 2 minutes, it really is well worth the time IMO. The cost? Provided the whisky is the same, this one probably costs less than using coke, for all I know. (I only choose Valencia oranges for any purpose including eating, over Navel, because they last 9 million times longer.) I took a pic, this is what it looked like at about 1:30. I almost forgot to mention, that's Elmer T. Lee bourbon in there, I highly recommend giving that a try, I think roughly $22 a bottle. (I have no rye whisky left.)
macddmac
macddmac
Jostenmeat,
I appreciate and respect the care that you take in mixing a proper cocktail as it is part of the whole experience of having one.
I bartended full time for six years before spending the next twenty in the USAF and it was during that time that I simplified my preferences. They have stayed with me until now and I have no regrets. Don't get me wrong, I still enjoy a nice single malt, neat with a water back on a chilly evening or a sassy little Tempranillo with a nice steak.
My whiskey of choice these days is a Denver product called Stranahan's. I would never put put coke or any other mixer in that one as I feel it would be sacrilegous.
Slainte, Mac
jostenmeat
Jostenmeat,
Slainte, Mac
Thank you for your service!
I will definitely keep my eyes out for Stranahan's, and yes, for how small-batch the outfit appears to be, I probably won't see any soon, but there is a store not far from me that can get almost anything. I don't know all the things you consider as "any mixer", but a lot of cocktailians would still mix it up, they'll try to create something with almost anything (for better and worse). For instance, this drink right here uses Knot Irish Whiskey, which right on the label says (2nd of 4 sentences), "You promise to drink The Knot straight up in a proper shot glass, rather than mixing it in some sort of novelty, tiny umbrella, fruit fiasco". Well, when I first had the below, I exclaimed that this whiskey was born for this drink (strawberry, balsamic, basil, thyme, lemon, oh a tiny bit of this strong pisco...) :p I think they should change their marketing line. :D Anyway, it's a sweeter whiskey, not quite but sort of bordering almost on a liqueur. 100 proof, $26. I guess strawberries and Irish whiskey is a well known combo, but I didn't find that out until after I had this one. Slainte!
G
Grador
Some nice green tea for me, it's getting quote cold* out right now.
*For Southern California
