connecticane88 said:
I was all set on how I was going to build my HT but now the fiance is putting the clamps down on the budget. I have a denon 3805 and boston acoustics vr1's. I was going to buy a svs pb-10 and a vrc center channel. I was also thinking of getting some cheaper surrounds that boston acoustics sells as well(in floor or in ceiling). Now she wants me to stop all together. How can I budget the rest of the pieces that I wanted. Do I need the $400 center to go with the vr series or could i get a cheaper one. Is there a cheaper sub that I will be saitisfied with? My room is 16 by 18. Any suggestions on cheaper equipment that is comprable would help, or should I just hold off and ave. Thanks
Unfortunately, or fortunately, not sure, but you have picked your receiver first and a couple of front speakers.
Speakers are the most important aspect in audio. So, by skimping on the center, your front sound-stage may not be satisfying as the sounds pan from left to right, or switches between the center and the matching left/right speakers. So, that is a consideration, a high one.
The sub. How much do you like or want good low frequency material from music or movies? As you downgrade, you are decreasing the effect and at times too much.
As to the surrounds, I doubt you will like the ceiling mounted speakers and not sure what those in floor speakers really are.
At the end, you are between a rock and a hard place. A new wife??? Give up on your dream???
