When I heard these GedLee Abbeys... It sounded like a clarinet being played in a large public restroom with tile walls and floors... I talked about how good his amp (vacuum tubes) and speaker cables seemed...[emphasis Duke's]
Earl Geddes designed the Abbeys for use with voltage-source (solid state) amps, and when a voltage-source-optimized speaker is driven by a tube amp, the frequency response can be severely degraded.
I don't know what the Abbey's impedance curve looks like, but will take an educated guess: A single peak in the bass region, and another peak associated with the crossover region, about 1.2 kHz. The nominal impedance is 8 ohms, the minimum (probably a broad minimum across the lower midrange region) perhaps 6 ohms, and for the sake of illustration let's assume the peak in the crossover region is 24 ohms... a 4-to-1 spread in the impedance curve is not unusual.
So we have our solid state amp putting out 2.83 volts into this load. That translates to 1 watt into 8 ohms, 1.33 watts into 6 ohms, and only 1/4 watt into that 24 ohm impedance peak. But that's okay, the speaker was designed for that kind of amp.
Now, what happens when we hook it up to a tube amp? A tube amp tends to put out approximately the same wattage into the load regardless of the impedance (within reason). So into 8 ohms, all is well. Into the 6 ohm region, our tube amp is a little anemic, but not much. But into that 24 ohm peak, our tube amp puts out
FOUR TIMES AS MUCH WATTAGE AS THE SPEAKER WAS VOICED FOR, so we have a
SCREAMING 6 dB PEAK! In the real world it might only end up being a 4 dB peak, but given the region (1.2 kHz ballpark), that peak will stick out like bold with the caps-lock on.
(It is possible that Earl's crossover topology results in the impedance peak being as much as an octave above or below the crossover frequency, but I'm willing to bet it's in there somewhere).
SO... if the most obvious feature of the speaker is a "horn" or "waveguide", and if the peak is in a region that sounds like "horn coloration", then of course the horn or waveguide gets blamed. But,
it's not the real culprit.
The real culprit is a mis-match between what kind of amp the speaker was designed for, and what kind of amp was used. This is not at all obvious to most observers, but as a designer of speakers that aspire to qualifying as "tube-friendly", it's something I deal with regularly.
-the result of the GedLee Summa/Gradient Revolution blind test (conducted either by Dr. Geddes or by Duke LeJeune, I don't remember)...
Earl designed and conducted the test, I brought the Gradients and assisted, and was given the distinguished honor of crouching down and shuffling the speakers around behind a curtain because we didn't have Harmon's budget. There were four speakers in the test, and an early version of the Summa tied with the Gradient for first place. The speaker I was "betting on" came in behind those two, followed by the decades-old JBL Model 4430 studio monitor, a truly landmark loudspeaker in my opinion, but that would be another post for another day.
