The Dayton Audio MK402 and MK442 Speaker Giveaway is Here! To show some love to our loyal Audioholics readers, we talked with our friends at Parts Express and they graciously allowed us to take our review units of their
Dayton Audio MK402 and MK442 Speakers and give them away to you!
The MK402 and MK442 speakers are a nearly textbook case of getting a full sound out of a small size. Dayton Audio claims the MK402 and MK442 has usable bass down to 60 Hz, which is quite a feat from a 4” bass driver. However, the bass driver used in these speakers is rather heavy-duty, considering the cost of the speakers.
For more information about these speakers, please take a look here:
To enter the Giveaway, simply:
1.
Register to receive the Audioholics and Parts Express email newsletters.
2. Respond using that same address if you are contacted as the winner.
PLEASE NOTE: By registering for the contest, you are agreeing to receive both the Audioholics and Parts Express email newsletters.
PRIZE DESCRIPTION
The MK402 and MK442 both use a ¾” silk-dome tweeter with ferrofluid cooling (the
Dayton Audio TD20F-4). Such a small diameter tweeter should have wide dispersion even at very high frequencies. The MK402 speakers use a four-element crossover network with a 2.5 kHz crossover frequency: an inductor and capacitor are used for a 12dB/octave low-pass filter on the woofer, and a capacitor is used for a 6dB/octave high-pass filter on the tweeter. There is also a resistor intended to pad the tweeter since the tweeter has a higher sensitivity than the woofer. The MK442 uses a more sophisticated 8-element crossover that has four capacitors, two inductors, and two resistors for an 18dB/ octave slope high-pass filter on the tweeter and a 12dB/octave low-pass filter on the woofers.
PRIZE: MK402 Bookshelf and MK442 Center Speakers
(Retail value: $
69/pr - MK402, MK442 - $50/ea)
IMPORTANT NOTE: Prize to be sent between August to September 2018 by Audioholics. Remember also that these are review units and not completely new "out of the box" speakers.
RULES: To enter, simply provide email address and follow confirmation to sign up for the Audioholics and Parts Express newsletters. One new subscriber who joins between 6/1/18 to 6/30/18 will be chosen at random as the system winner. Only one entry is accepted for the contest. The system will know if you already entered and will prevent you from multiple entries. * Don’t wait, the entry period ends June 30,
2018 at 11:59 PM EST!
*Winner must be U.S. or Canadian resident, 18 years old or older with valid email address.
