watching tv and music on dvd player...how?
Paulvader
Paulvader
I am a little bit confused...I've looked through the manual, and cannot find any reference as how to listen to music from the dvd player, while surfing channels on the tv - I'm missing something...I have tried a few things, but don't want to mess anything up! (ohhh the days when I'd use my rx 450 !! lol) any help is appreciated...oh ya...rx-v2500...:confused:
MDS
The way most receivers work is that you can select the video source and then independently select the audio source. This won't work if your dvd player is connected to the dvd input because that is also a video input. If your cable is connected to say 'video 1' and you also connect the analog cables from the dvd player to the 'cd' input, then you could select video 1 to view the picture from the cable box and then switch to cd to hear the audio only from the dvd player.
Paulvader
Paulvader
thanks for the reply, I'll check it out and see if I can get the cables straightened out. :)
