Bryce_H said:
We just watched the WOTW DTS tonight with my 3805 and had no problems. Sound was GREAT. I am running a set of Def Techs with the volume at -13.5 and it was loud. The Def Techs are very efficient (91 or 92).
Hmm, what does that -13.5
relate to????
You should know each receiver and where a person calibrates is different.
So your -13.5
Might actually be -25 for me or -2 for someone else.
Basically at what db level are you talking about, that would be much clearer to others.
I listen to my receiver at normal listening at -28 (which is 78db with 84db peaks)
At -15 is astronomical (at about 88db with 94db peaks)
The most I have gone is -3 (which relates to about 99db with 106db peaks)
Granted anything higher is ridiculous (actually those levels (-3) are insane)
I am very certain I could easily hit 118db (but why would I????)
Anyhow, I was just curious.......
Trim #'s are actually better associated with terms of room response....
At which I use these as a basis
-2.0 L
-2.0 R
-2.0 to +2.0 C
+2.0 SL
+2.0 SR
+1.5 SBL
+1.5 SBR
-10 to -8 S
Clearly by those numbers I like a lot of surround sound, or I am sitting to close to the front mains.
