SVS told me the SVS PB12-Plus/2 would be a great fit. I never got an answer at Hsu. I also noticed that PartsExpress had some Hsu designed Daytons. I was just looking for other opinions/options. A poster named WmAx (Chris) had made mention in several posts about getting better bang for buck from a DIY. I don't really care if I build or buy. I am confident I can build (with detailed plans that is) and actually enjoy building things but I only want to build if I am gonna be able to get a better value. Bottom line, I want a great sub at the best possible value in my budget. I am gonna measure my room and attach a drawing with exact dimensions/layout.
Oh and thanks about the setup post. I will check out the tips/tricks section in a moment.
Yes, you can build a sub that objectively performs superior to commercial offerings, if you follow suitable plans. In conjunction with user avaserfi, I did design a slot port subwoofer with specific bracing and dampening requirements using a 1st rate(in terms of non-linear distortion and over-all flexibility) driver called the Kappa Perfect VQ which is manufactured by Infinity. If maximum SQ is the point, you should build two(for a stereo matched pair) to get seamless integration with the main speakers. For reference, it is typical to achieve SPL of well over 120dB at the listening position, using two of these built to my specifications, and this is with virtually no audible distortion. Back down to under 120dB and under range(which is still far more SPL than you can ever use in real life for any real music or movies) and it will be a transparent device with no perceptible compression or distortion, assuming you use a sufficient amplifier and crossover system. I recommend the Behringer EP2500 amplifier with a fan replacement(the stock fan makes audible noise in home use). The best crossover to use is the Behringer DCX2496, or you can pay considerably more and get a DBX Driverack, which is a comparable alternative.
Here is the cut list and CAD illustrations, produced/provided by avaserfi(
this design is a direct descendant of his main DIY design that I specified):
http://forums.audioholics.com/forums/showthread.php?t=45528
A few people have built this sub so far, but as far as I know, only one has built the recommend stereo pair so far. He wrote a subjective review, if that's of any interest to you, which can be found here:
http://forums.audioholics.com/forums/showthread.php?t=46071
I want it to be clear that you can not audibly exceed the sound quality of these subwoofers, if built properly, at any cost. But you can target specific issues and increase performance there in. For example, if you wanted higher SPL, you can go with drivers of equal linearity and higher power handling and excursion, such as the JL Audio W7 drivers or TC Sounds/Audiopulse drivers(some still available from partsexpress.com). You can also get lower extension. The 12" Kappa Perfect can work effectively with high output to about 14-15Hz in the right enclosure. However, if you want high output at 10Hz or lower, you need to investigate other drivers/cabinets for this purpose. The cabinet plans given have effect extension to about 19Hz.
-Chris
