Shadowmonic
Shadowmonic
Pinpoint AM40 Black Pair
i want these two but their like 50 - 60 dollars
anyone know where to get a good deal?
dkane360
dkane360
Almost all of your questions are very basic questions that can be easily found googling or using the search function on the forums here. It isn't necessary to start a new thread for every question, especially when they all pertain to each other, such as your questions about speaker wire.
That being said, it seems that around $59 is the cheapest to find the wall mounts that you want.
http://www.amazon.com/Pinpoint-AM40-Side-clamping-speaker-mounts/dp/B002UV03MW/ref=pd_sxp_f_pt
The websites below are very commonly used on this site, and will be what most people recommend for various things. I would check these for products that you need, and they also have information that you might find helpful.
http://www.monoprice.com/home/index.asp
http://www.parts-express.com/home.cfm
http://www.standsandmounts.com/
I would also read the stickies on the top of each forum section, because they contain helpful basic information.
It doesn't mention anything about keyhole or integrated insert mounting for those speakers. The T15 has a keyhole slot so that you can mount them without drilling into them, which I presume is why you want the clamping kind.
These might work too.
