Wall Mounting In-Ceiling Speakers
rgbbhat72
Dear Audio Gurus
I currently have a set of Polk OWM3s wall mounted as Front Heights with the LCR being B&W 603s 2019 model and the HTM6.
I have an opportunity to get a pair of B&W CCM362 2 Way In-Ceiling Speakers at a good price. This will probably make it a B&W signature sound coming from front and Top :).
I cannot cut any holes in the Ceiling as I am on Rent and hence the Question
a. Is there a way that i can Wall Mount the In-Ceiling speakers
b. If No - OK understood as it was in line with my thinking.
c. If Yes- Do i just wall mount it straight or pointed to the Main Listening Position ( looks difficult even to imagine it)
d. Do i need to build a custom enclosure for me to put it into
Thank you for your advise and Seasons Greetings to you and your familes.
Regards
Rajesh
Dear Audio Gurus
Regards
Rajesh
You can if you build an enclosure for them. Without an enclosure they will sound awful.
