VSX-1014TX-K same as VSX-1014-S?
BomBom
Hi all and thanks for an informative forum! I will try to make my self clear writing in English.
Can someone confirm that the VSX-1014TX-K (US) is the same receiver as the VSX-1014-S (EU). The US site has no manual online if I’m correct?
There is some minor differences comparing the specifications from http://www.pioneerelectronics.com/pna/product/detail/0,,2076_4153_130866598_tab=B,00.html?compName=PNA_ProductDetailComponent and http://www.pioneer.se/se/product_detail.jsp?product_id=9168&taxonomy_id=62-98 but without the full spec its hard to tell.
Manual of the EU 1014 can be found here http://www.service.pioneer-eur.com/peeservice/RegistrInstrMan.nsf/search?openform&Modelnr=1014, so if someone that owns the receiver take o look at it and write down if there are any differences (except the obvious ones like colour and power voltage ;)), I would be grateful.
The bottom line is that the VSX-1014-S costs about 1000$ here and that I with some luck can get it from “bestbuy” for half that price when a friend of me goes over to the US.
But even if that’s not the same receiver, is it a good buy to get it from bestbuy if thinking of the specifications and price?
Mr.T
BomBom, as far as I know the differences are mainly the MCACC feature, the color of the casing Black/Silver and the power supply for the European differences of the 220VAC 60HZ over 110VAC 50HZ, otherwise they seem to be identical receivers. Here is a write up on the MCACC:
http://www.pioneerelectronics.com/pna/article/0,,2076_4151_20157532,00.html
Our usual spot of one the better beaches in Florida
___________________________________________
