Hello,
I have a 5.1 surround system setup (FL, FR, C, SL, SR and Sub). I have 5 Definitive Technology - ProMonitor speakers and a Polk Sub. I have a Yamaha AV Receiver RX-A780. I setup the system back in 2017.
Within the past 2 weeks I have been hearing voices out of both the center and rear SL/SR speakers. It makes the entire room echo and at times difficult to hear the voices. I know there can be voices out of the SL/SR speakers, but it should be minimal, and it is not. I did not change anything. Someone in my family did unplug/disconnect the power cable from the AC wall outlet. Not sure if this would cause the issue and change things.
I verified the speakers are connected properly. I ran the test tone to verify the sound is coming out of the correct speakers. I ran the YPAO and corrected any wiring (polarity) issues. I verified in the Layout the Surround speakers are set to Rear. My Power Amp Assign is at Basic. I have tried different Parametric EQ settings.
Typically, when watching a movie or TV show I have the DSP Parameter set to Standard. Sometimes might use Adventure, Sci-Fi or Spectacle. However, now these are causing the echo and voices coming out of Rear SL/SR mentioned above. Seems the best option now is selecting Surround which now most of the sound only comes out of the Center.
Now I am at a loss on what caused the issue or how to even correct it. My first option is to do a full reset and start over with all settings, but I fear it will not fix the issue.
Any thoughts would be appreciated. Thanks in advance.
