I just picked up a Vincent Pho 8 phono preamp. The horseshoe connector to the ground wire from my turntable (Technics SL D202) will not fit around the post for the preamps's ground terminal, which is thicker than any post I've seen on a preamp or receiver.
There's a hole in the post, but the ground connector won't fit into that either.
Does anyone have this phono preamp, and if so how did you connect your TT's ground to it?
So this is your preamp.
So the ground connector is the same as a speaker terminal.
You have too options. I think the first is the best.
Go to an auto parts store and buy a few spade connectors of the correct size, also buy the crimping tool for these auto connectors. I told you to buy a few as there is a slight learning curve to crimping if you have not done it before. I suspect the wire from the turntable is small gauge, so you will need a red spade of the correct size. The red connectors are the smallest, blue for larger wires and yellow for the largest.
Now cut off the connector that is too small. Now remove a little insulation from the end of the wire and crimp on the correct size connector.
Get enough bare wire to just go though the spade, and have the insulation JUST enter the spade. Now use the part of the crimping tool with the same color as the spade. Crimp it right in the middle of the cylindrical part of the spade. Crimp hard with one swoop and not in a limp wristed fashion.
Second option is to by a speaker banana plug to go in the whole. Buy one with a screw terminal in the end of it. You can get one at Radio Shack, if you can find one that is open and has stock left.
Now cut of the spade connector on the turntable and strip off enough insulation to fit though the whole is the banana plug, screw the terminal down and plug it into your preamp.
Does your ground terminal have a hole which is uncovered when you unscrew the top part? It probably does. In which case you have an easy quick solution. Cut off the spade and take off some insulation and poke the wire though the transverse hole uncovered when you unscrew the top part of the terminal, then srew down tight.
You will have to use a DIY solution to solve this and display at least a small modicom of skill.
