OK!, I've done my penance and can't find any Post which addresses this issue !
Just for starters, I'll mention some units I've looked at:
LG(s) DR787T & RC797T, Toshiba(s) D-R550 & D-VR650.
The above are DVD Recorders (not HDD) (a couple with VHS Tape ability) but all have Analog, Digital and QAM Tuners in them.
My situation is, I have an "Attic" Antenna VHF-UHF-FM, and Comcast Dig Pkg.
I wanna see/record the OTA NTSC/Analog Ch 2-69,
the OTA ATSC/Digital Ch 2.1-69.whatever,
and the PTV Cable too (via the QAM Tuner).
I've looked at the above units specifications (not an easy chore) and can't find any that have more than one "F" connector for the Antenna Input.
What I want to do is, feed my House Antenna in to the NTSC and ATSC, and the other feed for the Digital Cable into the QAM Tuner. Actually three (one for each) would be nice !
Does anyone know of a Unit which has two (2) Antenna inputs (minimum) for OTA Antenna and PTV Cable ?
Note: with the understanding that the Unit hopefully will internally split the NTSC and ATSC inside it,
and give me two sources to select channels (analog and digital),
and a third tier of Ch Selection for the QAM (Ch 2-1 thru 136-????)
UKK, I've just re-read this, and I'm not even sure I understand it !
Have a good Day !
