Very new to Home audio stuff have question
Drunder40
I have not dealt with buying new receivers/speakers in 26 years.. I have a Technics receiver, EQ, CD player and dual cassette deck (Laughing allowed).
I bought all this and the original Bose AM5 back I believe in 1988. My wife and I decided to upgrade. When looking for receivers and WRT power output I see stuff like:
"rated power output 2ch driven:
20hz to 20khz, 0.09% THD, 8 Ohms, Front (L/R) 80W + 80W
So I assume that means 80 Watts total power per speaker.. That I get.. but then I read:
Dynamic Power: Front (L/R) 8/6/4/2 Ohms 110/130/160/180 W
If the receiver is set for 8 Ohms and the speakers are 8 Ohm speakers then what is the true total power out to each speaker..
Just curious and thanks in advance
Drunder40
Thank-You for the quick reply.. I read that earlier but no it did not specifically address my question.. atleast I didn't see anything in that post.. What I posted was taken from a receiver manual
is typically what I see when researching receivers. It's kind of confusing and just looking for some clarification..
Any info would be greatly appreciated. Thanks again..
rojo
rojo
The 80WPC rating is an RMS rating. Dynamic power is a synonym for peak power -- the available power supplied during short bursts (measured in milliseconds) without clipping. However, comparing RMS power is usually the best way to compare apples to apples.
Be that as it may, different manufacturers perform their ratings differently, and there's no real industry-wide accepted method of rating. Truth be told, the ratings are all obtained from monophonic sources into some sort of reference measurement equipment, and they may reflect very little how smoothly the receiver can drive the more complex load of a loudspeaker with polyphonic signal anyway. They're more a way of comparing different models from the same manufacturer, really.
Most listening is done at < 10W. Having an amp / AVR capable of supplying more power will get you more headroom and better dynamic range without clipping, so getting something with more power makes sense from that point of view. But then again, I'd guess a 75W Marantz would have about the same clean output as a 100W Yamaha, just for the reasons explained in the article that agarwalro linked.
Just a suggestion here. It might be more worth your while to suggest a budget and features you're interested in, and maybe we can suggest a model or two that'll match. Describing the dimensions of the room you're trying to fill couldn't hurt, either.
Drunder40
Wow nice info. really appreciate it..
We don't have alot of cash to spend right now so we are limited with what we are looking to buy. My son inlaw gets a heck of a discount as
he works at the store we are looking to get this stuff at. The system we are looking at is:
Yamaha RX-V477
Energy CB-20 Bookshelf Speakers
Klipsch SW-350 Sub
We will start with this for now as it fits our budget (With the discount of course). Think they are picking it up as I type.
Guess there is no real way to know the exact power output to the speakers but I am sure it will be nice and loud.. Was just curious what all that
meant. Was very happy with my technics system and still can't believe it has lasted this long. Remote still works and all. My daughter will be getting that system.
Again appreciate all the replies.. Love this site.
rojo
rojo
Nooo, call them and tell them cancel the sub. Cancel the sub! If they've already gotten it, return it.
This one would be much better for the money.
The receiver and Energy speakers look good, though. Those Energy speakers have a sensitivity of 92dB/w/m according to Amazon. Any receiver would drive them well. I wouldn't even worry about the wattage rating of the receiver. It'll be plenty loud and clean.
Drunder40
Well the reason why I wanted the SW-350 is because my son in law has one and wow I love it. Base thumps right through you.. but wow that is a nice price on the one you linked. how much I will see what she paid for it. If it doesn't impress me then I will try the other one.. Thanks a bunch!
JMJVK
Bass thumping through you is nice, but if the sub can actually handle it cleanly, and deliver a complex and detailed sound in it's low frequency range, your end result will be much better. A bad sub can actually ruin the sound of an otherwise decent setup. Thumping isn't the sub's duty. It's duty is to deliver the low frequency stuff a standard speaker cannot yield properly. It completes your sound spectrum, and it should do so with just as much finesse and detail as you'd expect from main speakers.
Just my two cents; I think Sub-Woofers are the hardest item to properly gauge, pair-up and set on a system, and suggest you do a bit of reading prior to making your purchase.
Drunder40
Understand.. I have to say though that after listening to this setup, I friggin love it!! the sound is loud and amazing. Everything sounds soo clear.. The Sub sounds Awesom.. Much better than I was expecting..
Thanks again all for your replies.. One happy camper here!!!
rojo
rojo
Well, if you're happy, we're happy. Enjoy, and congrats on the new toys!
