Thanks LB06, that was really helpful. In able for me to translate that into action, I'll need suggestions about the below:
I understand that I need a pair of speakers: What brands/model that will achieve what I mentioned up there?
What's the device model/brand that will live and connect between my laptop's audio output and the speakers?
If you do not plan on upgrading to surround anytime soon, I would look into to leaving out the receiver and go with actively powered floorstanders. This will
- limit your number of devices to zero, which complies with your goal of having as little devices as possible AND
- you get to spend the entire amount on speakers alone, meaning you don't have to buy a separate receiver that's going to take 300 off your budget.
If you have multiple sources (besides your laptop) you can use your TV as a hub instead of the receiver. The DAC in the TV sucks, but you can get around that by using the digital audio output of your TV.
If you then get active speakers
with a DAC, you'll be able to connect the TV to the speakers using S/PDIF and the devices to your TV using hdmi. I'm talking about speakers with a connection like this (optical or coaxial S/PDIF, either is fine):
Those are the advantages. Here're the disadvantages:
- Less to no flexibility when it comes to upgrading. Since basically everything is contained within the speakers you're going to have to throw those out should you want to upgrade.
- Which also means no upgrading to surround
- Your TV probably will have to be on for you to get sound. Unless you take the TV out of the equation and connect your laptop and other devices directly to the speakers. Of course the number of devices will be limited to the number of inputs on the speakers and some may have to be analogue.
That regarding the infrastructure, or whatever you want to call it. As for the type of speakers (whether you go active or passive), I would STRONGLY recommend speakers with a wide frequency response on the low end. This may just eliminate the need for a separate subwoofer. Pay attention to the specification about the frequency response and then the first number (e.g.
50Hz - 20KHz). All else being equal, the lower the better. And if the specs don't specify the frequency response at +/-3dB or -6dB, it's not reliable, because then you don't know how they measured it.
In the low frequency department, you simply need volume, and since you want as few devices as possible (which I assume more or less precludes a subwoofer), volume is key which is why I suggested floorstanders rather than bookshelves.
Since the only time I ever used active speakers was when we had a PC with some silly Logitechs connected to it, I can't be of much help in giving you specific suggestions.
