Velodyne Woofer replacement
drybo
drybo
Have a "12 Velodyne Ct-120 and would like any and all opinions on a good replacement woofer. The Velo is still in good shape but is "boomy", just want to experiment w/o going over $100-$150. I had a Infinity kappa perfect sub in my car years ago that I thought was very good, may look at used on ebay... Any thoughts appreciated.
Sheep
Sheep
The exact woofer that came out of the Subwoofer.
You do not want to start swaping in different woofers. The Box was designed for one.
SheepStar
drybo
drybo
Thanks, you probably saved me a lot of problems I don't need (If it aint broke dont fix it) I says to myself.
Sheep
Sheep
No problem.
Now, theres nothing saying building your own DIY woofer is a bad idea. :D
SheepStar
N
Nick250
I don't think you will get anything halfway decent for $150 even used. If you find a used Hsu or SVS on eBay in your price range it certainly would worth checking out. I am more familiar with ID subs than retail, bearing that in mind I think decent ID subs starts with the Hsu STF1 for $299.
Nick
http://www.hsuresearch.com/products/
Sheep
Sheep
Nick
Um, he was talking about removing the woofer from his CT-120 and puting a better one, not buying a whole powered sub for 150. :)
SheepStar
markw
Possibly a cheap fix.
Try moving it to a different position. This can make a not-to-subtle change in it's overall oerformance.
billy p
billy p
SheepStar
Can the same be said, for speakers as well?:eek:
N
Nick250
SheepStar
Ah, I misunderstood.
Sheep
Sheep
Most likely, yes.
The crossover is design for those drivers, and may not work well with others. And if the speaker is designs to reproduce bass, the tuning and size may be off.
SheepStar
