I have the same speakers and would be curious to see what you choose and how you feel about it. Either post back here or PM me, please.
I have Athena AS-P300 sub and I am not too pleased with it. It fills in the speakers but sounds too boomy when louder. I have to turn it even lower for music. I could experiment with positioning but I suspect it wouldn't do me much good for the amount of hassle.
Hi All,
Since I didn't really get any great responses comparing the two subs, I opted to go for the velodyne since they are a 100% sub manufacturer, wheras klipsch manufacturers a bunch of other stuff. Took the baby home, it is massive for my place. And completely awsome. Shakes my 700sf condo like there was no tomorrow. While I was testing, I was completely stressed out that my neighbours would come banging on my door any second. It is a great sub that hits very low and hard. My Athena 8'' might as well be a tweeter compared to this thing. Now I gotta find a way to bolt down all my picture frames on my walls so that it doesn't vibrate and fall off while playing. I am very happy with the sub. But only three non critical pitfalls:
1) It comes with four little stick on feet that is pretty much useless on carpet as they are not very tall. So basically, if you stick them on and put the sub down, it's pretty much sitting on the carpet/floor as the feet sink in. And i have high traffic carpet too....I've heard someone on another forum say to just buy some hockey pucks and put them underneath and that will do a better job of separation. If anyone has a better idea, please let me know for my downstairs neighbours sake.
2) The manual is outdated: Night mode is on when the the blue led's are dimmer, and off when they are brighter. In the manual is says it's on when the led's flash. Don't listen to that cuz it's really really confusing.
3) Volume control is a *****. There's no knob for it so you can't really tell what the volume level is at. Took me quite a bit of research online to figure it out. The key is the flashing middle light when you press volume button up and down. In case anyone else has bought this sub, this is what it means:
When you adjust the volume, it flashes really quickly at first which means nothing.
Then...
It will flash slow for example 4 flashes
It will then flash fast for example 3 flashes
This means that your volume is 4 flashes x 10 = 40 and 3 flashes x 2 = 6
For a total of 46 and that's your final volume.
No idea who the brains behind that one was. Probably cost them more to make than a simple knob and 1000% more clumsy.
