Haha i thought the exact thing about the tv. It looked like a 47" in the first pics. But proper mounting height can make all the difference. NOW it looks like the great size it truly is...65"... Drooool
I can honestly say that for the $ you have spent on the system you couldnt have done much better if at all. Those Infinitys are known for being such a great buy at their price point. The same is true of the new FV12. Excellent combination of budget & quality sound. Thats probably the exact system id put together for the money, just plain well done!!!
Good placement. Id bring those towers off the back wall a little more to minimize the chance of boomy bass. Id recommend at least 20" from the back of cabinet to the wall.
Have you done the "bass crawl" to see if your sub is placed as best as you can?
Some wall treatments & an isolation platform for the sub would probably help quite a bit.
If your house is on a raised foundation you could easily pop 3 small holes in the floor (1 behind each tower & 1 behind av rack). Then you ould run the wires under the floor for a clean look. Or pop the baseboard off, cut a groove out of drywall near floor & run the wires behind where the baseboard would be put back.
Very fun system youve got there! Its obvious you spent wisely! ENJOY!!
FYi: give your sub a good 30-50 hrs to break in. New subs get noticably better over time. Its a gift that keeps giving for a little while
