<font color='#000000'>I'm assuming you have a DVD-A/SACD player. Like Ross said, you need 6 cables for your 5.1 anolog sound for DVD-A/SACD and you ALSO need a digital cable. Either Toslink (optical) or digital coax. The 6 anaolg cables are for DVD-A/SACD and the digital cable is for DTS, PLII, THX and other DSPs. When playing a DVD-A./SACD press the multi function button, when playing a DVD or CD you need to press AMP then whatever sound field you want to use (DTS, PLII, etc.).
In total, you should have 7 lines for audio hooked up, minimum. You will also need a video line like S-Video or Component.
Have you run the YPAO? This might give you some clues to your center channel problem.
Shinerman</font>
