Using XM through Denon 2308CI
dt403
Hi, I just hooked up an XM unit through my Denon receiver. Everything works fine and sounds great, except for using the remote. I can scroll through channels with the + and - buttons on the rear remote panel. But when i try using the number pad to go directly to a channel it switches between sources, which is the alternate function of the number pad. Anyway to switch this so it uses the numbers instead? Thanks.
