using thx processing
twisted3
do you calibrate with it off then turn it on or do you turn it on and then calibrate using test tones from DVE?
DVE will let you level match, hence, you should do that beforehand, then set whatever THX mode you want.
MDS
THX is post-processing so I would think it would be better to calibrate first and then turn on THX if you want to use it. You probably won't use THX at all times so if you calibrate with it on, it may not sound right when it is off.
