sorry I meant high current capabilities of 85 amps. I can't find the Pio SC-05 high current numbers anywhere or is it not high current design?
Yeah, for a SS amp, the critical parameters are continuous power rating (some companies don't do this!), and THD + N, and the minimum ohm load that the amp is able to drive.
To a lesser extent, the S/N is a spec to look for, but this is more critical on a pre-amp than an amp.
My gut tells me that you aren't going to hear much, if any difference b/w the Pio and the HK. The only reason that I haven't told you this before is that the Pio is class D and the HK is class AB, so I did not want to bias your opinion before you could check it out for yourself and let us know your thoughts.
I'm not generally a fan of class D for home hi-fi, but I also know that it is mostly just human bias that doesn't follow what I see in the data and measurements and listening. My biggest complaint is that Class D and SMPS usually go hand in hand. And, so far it seems that Pio has done it right! I can't remember if Pio uses SMPS or Linear PS.
