USB to Serial Adapter
Alex2507
Alex2507
I need a USB to serial adapter. This is the one I'm looking at:
Amazon.com: Keyspan by Tripp Lite USA-19HS Hi-Speed USB Serial Adapter, PC, MAC, supports Cisco Break Sequence: Electronics
I read some reviews on Amazon.
I also saw this:
Staples USB-to-Serial Adapter | Staples®
The negative review and the product details both talked about 64 bit machines which I have. Mine is Vista. It's this one:
Asus X83VM-X1 Review - Laptops - CNET Reviews
I suppose if I just used my XP desktop with a regular RS232 cable that was close to 15' in length like this one:
15ft White RS232 Extension Cable with DB-9 Male-to-Female Connectors: Amazon.com: Industrial & Scientific
I could do that ... but then there's no portability ... but then again this is likely to be a one time use thing.
BoredSysAdmin
BoredSysAdmin
As IT person USB to Serial adapters are bane of my existence. None of them properly work If I need to interrupt Cisco equipment boot-up process in order to do a factory reset
I just settled down to do my serial required work with an older biz series laptop with a real serial port.
That said I haven't tried the Keyspan model and reviews look promising, still I will believe then I see it.
here is a good review:
Amazon.com: Tom's review of Keyspan by Tripp Lite USA-19HS Hi-Speed US...
I'd go with the first one probably, but the big advantage of the Staples one is you can quickly and easily return it (even if it works lol)
If it is a one time thing, do it with the desktop.
Alex2507
Alex2507
Very informative and compelling review ... almost like I wrote it myself. :D
I just bought both but I found a 15 footer that shipped free for a couple a cents less.
I figure that when that CC bill comes in I'm going to be so dead that another 25 bucks isn't going to kill me.
panteragstk
panteragstk
I have 2 usb to serial converters I use for RS232 for controlling the HT and they both work without issue. Past that they are supposed to be a huge pain.
Ponzio
Ponzio
Alex ... is this for a Yamaha AVR (ex. RX-V2700), using the Yamaha RcvMgr2700.v1.0 app? If so, you're also going to need a null modem adaptor or a USB to null-modem serial cable.
Alex2507
Alex2507
No, it's for that Crestron MC2W that BMX is helping me out with.
I do have a RX-V2600 that has an RS232 port but I wouldn't know what to do with it anyway.
crossedover
crossedover
All of the issues I've seen is making sure the "com" port is selected in the proper manor. I use a gigaware branded cable with no issues on xp pro and 7 ultimate
