I really like my Onkyo DVD Receiver (CS-V720, also labeled DR-UN7), but I could do better than the 2 main speakers that came with it...
Here are the specs for the built-in amp:
Power Output:
2 ch driven: 16W + 16W at 8 Ohms, 1 kHz, FTC
23W + 23W at 4 Ohms, 1 kHz, FTC
1 ch driven: 30 W at 4 Ohms, 1 kHz, FTC
Damping factor: 70 (front, 1 kHz, 8 Ohm)
Input Sensitivity and Impedance: 150 mV/47 kOhm (LINE)
Output Level and Impedance: 120 mV/2.2 kOhm (REC OUT)
Frequency Response: 10 Hz - 100 kHz
Signal-to-Noise Ratio: 100 dB
Speaker Impedance: 4 Ohm - 16 Ohm
Here are the specs for the 2 stock speakers:
Type: 2-way bass reflex
Impedance: 4 Ohms
Max input power: 70 W
Output sound pressure level: 82 dB/W/m
Freq. Response: 50 Hz - 35 kHz
X-over Freq.: 6.5 kHz
Woofer: 13 cm A-OMF cone
Tweeter: 2.5 cm soft cone
I was thinking about replacing these with a pair of Axiom M3's or maybe Bose 301V's... I use this system for music only, and it's stationed in a fairly small room... I have an Onkyo subwoofer.
I am kind of wondering, since the stock speakers are rated at 4 Ohms impedance, whether I should look for 4-Ohm speakers or should this system be able to drive the Axioms reasonably well?
Appreciate the help...
