upgradeitis - *cough* must seek help....
Sheep
Sheep
edwelly said:
no, you are probably right. I am just surprised that such a monster is realy such a wuss. I mean this thing is nice as I am comparing to a couple Pioneer and other Sony's I have had... And it seems to have had all of the characteristics of other high end receivers as far as weight, features and even the metal volume knob :)
I know what you mean about the sony being beefy. My friends dad has an older one, from the 90's and its BIG. I never get to hear it, as they never use it. They are the "we don't touch anything electronic/the TV speakers are fine" kind of people.
SheepStar
HookedOnSound
HookedOnSound
edwelly said:
It's easier to find a buddy to bring over his speakers vs. unhooking his amp ;) so that's what I meant by that. I guess I am still in denial or shock... Didn't see that one coming... :(
Ok, that answer I can understand. You're right about being easier less cables to plug and all. But this won't tell the whole story, since speakers have diff. load characteristics it will almost certainly change the sound, for better or worse.
I don't think your Sony Receiver is up for the task of powering those Monitor 7's, look at the specs carefully. They will take up to 130 wpc of per channel.
Most of the time, Sony rates the power/distortion @ 1khz only, not the whole spectrum, I am wondering what kind of distortion you are experiencing if you playing you're unit at higher power output levels, this could also be a reason why you say it doesn't sound good....
This is will probably take some experimenting to get it all sorted out. Whatever you do, do it systematically in a logical methodical way. Example, Change one thing at a time, try to observe/hear for changes and return to a prior config to confirm the diff. etc. No hard rules, just do it in a fashion that suits you.
Good Luck
edwelly
edwelly
OK - so if I were to look into getting a new amp would a Rotel RB-976AX six channel amplifier, 6x60 - model work? I have a friend who has a used one for sell that I may be able to get for around $300 - $350 - Rotel RB-976AX six channel amplifier, 6x60. I could bridge the front 3 channels for 150w x 3 and use the Sony for the rears - maybe???
Thanks!!!
Review = http://www.avrev.com/equip/rotelrb976/
Also, HAPPY THANKSGIVING!!!
