chris357
chris357
i've never had much luck with the URC's .. I've had 2 of the rebadged B&K whcih I think are the urc mc 750? first part is they need a serial cable to connect to the PC and next it seems like you need to be an engineer to program them.. both times I got frustrated and resold them.. luckily I may be the only idiot out there and never lost any money.
if the new ones connect via usb that would be a big help. I have had a harmony 880 and it programmed easy as pie.
bandphan
bandphan
All current URC remotes that are programmable via editor software are mini usb. The current CCP software for the remotes is easy to work with once the curve is learned. For the dollar URC and RTI are an excellent value if you need mid-upper level control.
chris357
chris357
i have a friend who likes the RTI stuff.. its pricey though. other than having alot of different remotes laying around being single it doesnt bother me.. but sometimes its a pain when the remote I need is all the way on the other side of the room :) lol
MidnightSensi
MidnightSensi
I have a RTI T3-V, and it is pretty cool. I use it to control my lighting (Lutron HomeWorks) and a portion of my home theater. My amps and so forth don't have 12v triggers, but it works well for controlling everything else.
Programming wasn't bad, certainly easier than a Crestron... I've messed with Crestron systems in a few applications and find them very cumbersome: hard to program, software running on the devices runs on Windows and gets the blue screen of death, for a while they had battery issues in their bigger touchscreens, they are too expensive and don't offer much over less expensive versions. Their new mid-sized panel looks like crap, so you really have to go to the top of the line one, and thats super expensive. Battery life is better but not great, and they are brick heavy. Then their wall unit looks like something out of a old sci-fi movie.
The thing with universal remotes, is that without feedback, don't program macros. If something gets changed without the remote, it has no idea, and it just becomes more of a pain than it is worth. Keep the programming simple, just another version of your remotes in one box. For my processor I keep the volume, shortcuts to my main inputs, and my most often used modes (Pure Direct Stereo and THX). Don't program "Watch a Movie" ... if it misses one fire it'll just get confused. Doesn't matter which one you use, in my experience, they all get confused doing that eventually.
