Hi,
My in-laws purchased and had some one install a Home Theater system a couple of years ago and I have since seen them struggle with mundane activities such as turning on their TV, Rcvr and DVD to watch a movie. In other words, they are prime candidates for an easy to use activity-based universal remote such as Harmony 550. Unfortunately, their TV is in one corner of the living room while all their A/V equipment is on the other corner of the same wall, about 10 feet away. All their A/V equipments are enclosed inside a wood cabinet and a wall mounted IR sensor outside the cabinet sends the IR signal from remote via an IR hub to the individual devices. The IR sensor for the A/V devices and TV form rougly 45 degree angle from center of the viewing area.
1. Is it possible to program a pause in an activity such as "Watch DVD" so that the remote can be pointed to TV to turn on the TV set to the right input (VIDEO1, etc.) and then point to A/V equipments to turn them on? OR
2. Do I have to set up two separate activities ("Watch DVD" and "Turn on TV").
3. When the power off button is pressed on the Harmony, does it send power off only to devices that were turned on by the previous activity? If this is the case, I may have a problem turning off both TV and the A/V devices if they are turned on by two separate activities.
Any ideas/suggestion would be appreciated - any major changes such as getting a RF sensor on the back wall and threading wires, etc. would get vetoed by my mother-in-law in an instant.
Thanks
Srini
