Hello everyone, I've been lurking on the boards for a while but this is my first time posting. I've got a unique problem with my home theater/PC sound setup and I have not been able to find a solution after much fruitless searching.
Why playing MP3 music on my computer, or playing streaming videos/music from the internet, my subwoofer is not engaging (making no sound). I've tested every aspect of the connection I can think of.
The subwoofer is hooked up correctly and has power. It works fine when playing audio from my TV, DVD player, and when I run a speaker (noise) check on my computer through the Creative Audio Console. When I run games on my PC, I can hear and feel the subwoofer kicking in. However, when I try to play music, nothing.
I have tried re-installing every driver and program related to the problem. Firefox, Windows Media Player, Creative SoundWorks, the XFi Drivers and the Audio Console have all been reinstalled to no avail. What can I do to get my subwoofer to work when I'm playing music?
Here are the hardware components of my setup:
Creative SoundBlaster XFi
Yamaha RX-V663 Receiver
Definitive ProSub 800 (associated with a Definitive ProMonitor 1000 5.1 system)
The sound card is connected to the receiver via 3x minijack-to-RCA connectors and utilizes the multi-channel analog input. I changed this from an optical connection when I realized the XFi does not output discreet sound when using a digital connection (speaker test would throw rear channels to both front and rear speakers).
The receiver is connected to the subwoofer through a standard Monster subwoofer cable.
On a related note, what should I set the low freq crossover when using the sub for PC sound? I tried all settings, and it didn't fix the subwoofer problem, but I'm just trying to figure out where it should be in the long run.
Thanks in advance for any help.
