Jedi2016
I thought the movie was okay. I had a gift card that day, so I paid only about two bucks for it. I prefer the original, but the sequel was a decent enough popcorn flick.
Unfortunately, I don't remember the opening scene, specifically. But overall, the effects looked very realistic in this movie; the best I have seen, overall. A perfect blend of real-action effects combined with CGI to 'polish' it. Usually, I can *easily* see the CGI artifacts in movies. This one, most effects were convincing in most scenes without obvious CGI artifacts.j_garcia said:Odd, I thought the special effects in the opening scene in particular, were terrible.
Which scenes and details were 'far too obvious'? The movie actually used very little CGI; except in distant or very fast moving scenes, and for 'polishing'. Nearly all of the monsters were make up(except for help in transformation or in distant/fast scenes) and even the helicopter scene near the end used very little CGI, except in the fastest moving sections, of course. The truck/cliff chase scene; the main CGI for example was the addition of wings and the removal of suspension wires from the stunt man they had suspended, pulling along side the truck as it was driven. Please point to specific times/scenes, as I'll be glad to go over them to review where they are obvious.j_garcia said:The hair and the movement is pretty well done, however the CG in this movie was far too obvious. Narnia is an example of well integrated CG, IMO.
You have to get a new television man, the one you have is probably on it's last leg.Dolby CP-200 said:I’ve decided to revisit (Underworld Evolution) tonight with a sound experiment. First of I need to recalibrate my ageing (SONY KX-27 PS1) she’s old but she’ll hold.![]()
From what I can perceive, one of the top tier plasmas(current generation Pioneer and Panasonic) is virtually as good in overall image quality as a top quality CRT. I held out for a long time, and I almost bought the current 34" Sony CRT HDTV, but I ended up with a current generation Panasonic 42" HDTV plasma. I compared it as best I could to a professional Trinitron FD computer monitor that I have, and the plasma(when adjusted and set up properly) was only a little worse when compared side by side. The differences virtually disappear without a direct side by side reference. As for LCD televisions, the best I have found so far is the current generation Sony Bravia XBR line. But from what I have observed in uncontrolled scenarios, it is not up to the image quality level of the top tier plasmas.Dolby CP-200 said:I could get credit card from my building society to purchase a 34” LCD, but you know I how feel about part my ole SONY CRT for LCD.![]()
I am not a television technician. I can not answer this question.Dolby CP-200 said:WmAx
Also the gray scale as a slight tint of (red) but if only when brightness is set to a level where it would become visible. I did an adjustment a around late of last year which corrected the above, but it only lasted a few months.
Could be a dry joint or a component that needs serviceable replacement?
